K5 Blazer 1969-1994
Platform: Truck, GMT 400
1984 K-5 - Timing Issues
Old May 22, 2010 | 11:34 AM
cduarte1982's Avatar
Default 1984 K-5 - Timing Issues
84 K-5 4 bbl carb. Set timing at 5 degrees - tightened the distributor while the engine is running - checked timing and it was still ok. Tugged on distributor and it didn't move and the timing was still ok. Shut the engine off, restart the engine and the timing has moved anywhere from 5 - 8 degrees. The engine has new timing chains and gears and new distributor. I can't figure out why the timing is moving. Can anyone help?
Old May 22, 2010 | 12:01 PM
maxxman04's Avatar
worn distributor gear, sticky vacuum advance, vacuum leak, timing checked at different idle rpms.
Old May 22, 2010 | 6:26 PM
72c10gunn's Avatar
If u put a roller cam in it you need a cam button to keep it from walking and causing eratic timing
jmms
HHR
Apr 17, 2015 4:22 AM
nashcarjay
Mar 11, 2012 5:42 PM
01yeehaw94
Mar 29, 2008 8:41 PM
snowcatns
Aug 14, 2007 8:34 PM
LetsGoMets78
Cobalt
Dec 18, 2006 2:48 PM
