K5 Blazer 1969-1994
Platform: Truck, GMT 400
1985 K5 Silverado Blazer backfiring issues
Old Nov 4, 2007 | 2:51 PM
Dibsing's Avatar
Default 1985 K5 Silverado Blazer backfiring issues
Hey guys
Been having a horrible week with my new blazer i bought. Its a 1985 K5 Silverado Blazer, auto (3 speed auto w/ od), 350 (not original motor).
When the truck starts it idles fine at around 750, and when you put it into gear the passenger side exhaust pops/backfires. It only occurs on the passenger side not the driver side at all.
I have done to try and fix it
-new plugs
-new wires
-rebuilt carb
-timing is set
-firing order is correct
-vaccume is at 24 ' Hg in P/N, 20 with brakes on, and around 14'Hg in R/D/1/2 with brakes on
I do have a leaking brake booster, but i had redone the header gaskets and put them back on the truck and now it is all messed up again. It was not backfiring at all before i took off the headers to put in the new gasket
Any info would be greatly appericiated
Dibsing[/align]
Old Nov 12, 2007 | 5:02 PM
k5kid's Avatar
Default RE: 1985 K5 Silverado Blazer backfiring issues
check your fireing order to make shure that you didn"t cross any...fireing order 1-8-4-3-6-5-7-2 clock wise on the distributor.
Old Nov 18, 2007 | 10:13 PM
baggedk5's Avatar
check for a leaky gasket or collector. had this issue not long ago, found the problem at the collector.
Old Dec 3, 2007 | 12:42 PM
dleonard2844's Avatar
maybe your gasket got pinched?
Mitnelson
Jul 6, 2014 4:05 PM
dablaza85
Oct 16, 2008 4:38 PM
s10blazerproject
Apr 15, 2008 5:51 PM
gbear1023
K5 Blazer
Apr 12, 2008 8:25 PM
infamous
Jan 11, 2007 4:09 PM
