K5 Blazer 1969-1994
Platform: Truck, GMT 400
1990 K-5 Blazer 5.7L starts then stalls when cold...help!
Old Apr 6, 2011 | 9:31 PM
BillyBlazin'Trails's Avatar
Default 1990 K-5 Blazer 5.7L starts then stalls when cold...help!
When cold it starts then stalls over and over again and will not stay running until completely warm. The only code I could pick up was a "12" which Im pretty sure means normal operation mode. Ive changed the sparksplugs, wires, distributor cap & rotor, and fuel filter and still does the same thing. I had oil problems last summer so i think it could be the oil pressure sensor/switch. However, since it only runs well when completely warmed up tells me that it could be the coolant temp. switch. Am I on the right track? If so, where are these switch/sensors located and how can I varify if they are functioning properly?
Old Apr 6, 2011 | 10:00 PM
EinST's Avatar
Welcome to the forum. I've no idea what the problem could be but I was able to find a drawing for you:
Dfmatt
1988 - 1998 (GMT400)
19
Aug 29, 2024 1:02 AM
dalkins1
Nov 13, 2012 2:56 PM
mark 66
Uplander
Apr 22, 2010 10:09 PM
snowonweb
Oct 25, 2008 3:42 PM
dalkins1
Jan 27, 2007 11:18 AM
