2WD K5 Blazers and Jimmys
mine is a 79 bought it as a real grandpa wagon, lowered the front 4" after many people calling me a liar and chevy never made a 2wd blazer, has 400 hp 350 in it, monster tach and other things posi rear with 3:43 gears soon, and trans shiftkit and tork converter in near future, this ol girl dont look as good as when i bought it, but it dont matter when the 3" exhaust barks and im gone lol
i only had the 1, and have only seen 1 other, a friend of mine had 1 years ago, and called it the doughnut machine, crank the wheel and floor it and it would do doughnuts till the tires blew, i put a 1 ton sway bar in mine and it made mine handle like a gocart
it is the funnest truck i have ever had
I like the sway bar idea! Are they installed front and rear? I have not been doing anything too crazy as far as burnouts or hod rodding. Mainly because I just bought it and I am not sure if this motor will hold up yet. The guy I got it from said the motor was rebuilt a year ago ( or so ) but I have since found some things that concern me. Possibly lack of experience or just plain lack of concern! Either way the signs on this motor has convinced me that it was put together by an incompetent person!!!!
check the oil guage, if at psi or greater, bottom end is goo,after that do a compression test, all cylinders should be at 150 psi or higher and no more than 20 psi variance,if it passes that then u have a good basis, also if it doesnt blow smoke then awesome, u have the good foundation to start with. i just swapped the front sway bar, most blazers didnt have q rear, but suburbans did and i want to find the rear from 1. another good mod, is a power assist setup from a late 70's 1/2 ton diesel, it uses the power steering pump to power the brakes, along with the larger disks, make stopping waaay better, like a new car would stop
Hell yea. As far as my guages they are not working correctly right now and as soon as I am able to walk again after my surgury I will be installing and aftermarket set! Then I will be checking all the cylinders and such. Thanks
nika17
Oct 19, 2008 6:05 PM
