S-10 & Blazer 1982-2005
my blazers goin ashes
Old Nov 14, 2006 | 9:06 PM
94 blazin's Avatar
Default my blazers goin ashes
i did an oil change, air filter, n plug wires... it jus started recently dying out on me, it won't stay idling, n when i do get it to idle it will jus bog down n cut off, i did by chance get it to run long enough to get home but it seems dat if i stomp on the gas or jus gas it, it starts to sputter on me...
i had problems before where the vehichle would bog down n lack power but i changed the plug wires since n have had no probs in that manner... i also saw a small stream of white smoke comming out of my airfilter, smelled rich like oil.... right now the vehichle is in my drive way, i had a few small hose lines dryrotted away but i fixed those... i thinkin it might be the feul filter but i'm not sure... when i started havin the problems it got so bad i had to hold da brake wit my left foot n idle it manually with da gas, but even den it would jus bog down n die out.... do u have any clue of what might be happening.... i'd appreciate any advice u can give...
Old Nov 14, 2006 | 9:18 PM
buster's Avatar
Default RE: my blazers goin ashes
da first ting ya need da do is tell us what ya drivin (be specific, include engine)
Old Nov 14, 2006 | 9:24 PM
94 blazin's Avatar
my bad: its a 1994 chevy blazer 4door 4x4 i tink its a 3.6 liter v6 , automatic.... the vehichle has 211,000miles
Old Nov 14, 2006 | 10:11 PM
buster's Avatar
So is it an S10 Blazer or the full size?
Old Nov 14, 2006 | 10:35 PM
94 blazin's Avatar
oops an s10 blazer, i jus went out n started it up from bein cold an she fired right up but after a few seconds it started to idle real hard, as if it were goin to die out...
Old Nov 14, 2006 | 11:40 PM
94 blazin's Avatar
uh can anyone help?!
Old Nov 15, 2006 | 12:27 AM
70mopar's Avatar
check out your post on 94' s10 blazer 3.6liter v6, "?" for a possible answer-and your engine is more than likely the 4.3L
Old Nov 15, 2006 | 1:22 PM
94 blazin's Avatar
this is the earlier post with what the truck is doin, or started off doin
HUGGYY
Jun 23, 2011 11:10 AM
kaner
Sep 8, 2010 6:42 PM
SlowLeak
10
Sep 25, 2009 3:50 PM
parsons
Apr 28, 2008 7:10 PM
85 wrangler
Nov 16, 2006 1:32 PM
