K5 Blazer 1969-1994
Platform: Truck, GMT 400
79-82 K5 Blazer
Old Jun 28, 2010 | 7:54 PM
andrij13's Avatar
Default 79-82 K5 Blazer
So, I had an '88 Honda Civic which I TRADED for a '79 Blazer. The guy I got it from put a 350 from an '82 in it. It has a few issues, but one I cant figure out is, WHERE DOES THE DARN VACUUM HOSE FROM THE TH350 MODULATOR GO?!
I'm sure that has something to do with my rough shifting? but right now I hear a bunch of grinding and whining and clanking.
any help?
really don't know where that damn hose goes.
thanks for any help in advance!
Old Jun 28, 2010 | 10:07 PM
frickenbored's Avatar
Some where on the carburator there will be little vaccum ports, they should be plugged with rubber caps, im not sure what carburator you have but if its a holley the ports are on the back of the carb. doesn't matter what port you pick. Heres what you wanna look for:
Old Jun 29, 2010 | 4:10 PM
andrij13's Avatar
its a rochester quadrajet. 4 barrel. i think i see which one i need to hook up now, all i have to do is get the right size vacuum line, and hook up the other ones
Old Jul 1, 2010 | 3:28 PM
andrij13's Avatar
its actually a TH400. but that still doesnt solve my issues
Old Jul 3, 2010 | 10:13 PM
whining grinding and clanking could be a rear end...
Old Jul 4, 2010 | 2:11 AM
2wd-K5's Avatar
there is a vacum nipple right behind the carb, it sticks strait up for the trans, and it is why you have hard shifting. i dissconnect mine once in a while to firm up my shifts for shock value when hauling my friends
Eddie02780
May 11, 2015 5:19 PM
stshadow
Apr 22, 2011 9:48 PM
