K5 Blazer 1969-1994
Platform: Truck, GMT 400
81 C10 starting issues
Old Nov 7, 2018 | 9:49 AM
Dkarns90's Avatar
Default 81 C10 starting issues
Hey guys I am new here and new to the C10 world. I bought an 81 C10 about a month ago. It has a 350 sbc swapped into it. Motor and trans run great but I have a starting issues. On a fresh start the truck starts with no problem, even driving for an hour or so then parking and starting again there is no issue, but if I drive it around for a longer period of time and go to start it, it won’t even try to crank or anything, it has to cool down for two hours or so it seems and then it will fire right up. It also has a new battery. Any idea what would cause this?
Old Nov 7, 2018 | 7:06 PM
oilcanhenry's Avatar
Likely a bad ICM. It gets too hot and has to cool down to operate again.
Old Nov 7, 2018 | 7:32 PM
Dkarns90's Avatar
I’m sorry but what do you mean by ICM?
Old Nov 8, 2018 | 4:20 AM
Ignition Control Module.
Old Nov 8, 2018 | 8:55 AM
Dkarns90's Avatar
Ok it’s only a $30 part and easy to change so I give it a shot. Thank you
