K5 Blazer 1969-1994
Platform: Truck, GMT 400
88 K5 Blazer - Radiator Replacement
Old May 5, 2010 | 12:19 PM
dschlact's Avatar
Default 88 K5 Blazer - Radiator Replacement
Hi - My radiator has several "pin hole" leaks and needs to be replaced. It seems pretty straightforward and is a project I want to do on my own, but I would love to hear suggestions or things to check before tearing it apart. Is it as simple as draining the fluid, removing hoses, removing/replacing radiator, re-attaching hoses (replacing hoses that are worn) and filling it back up - any major steps or checks I am missing?
Thanks in advance!
Dave
Old May 5, 2010 | 1:00 PM
maxxman04's Avatar
you pretty much got the process. pretty straight forward and simple.
Old May 5, 2010 | 1:54 PM
dschlact's Avatar
thanks - just wanted to confirm that i wouldn't have to mess with any fan clutch, water pump, etc. I will be inspecting the water pump while I am in there and replacing if necessary...might just go ahead a replace anyway along with belts, but not sure - just depends how inspired I am.
Thanks again!
Dave
j5403h
Sep 12, 2015 7:30 PM
drew912011
Mar 28, 2015 1:05 PM
WanderingOak
Feb 13, 2012 6:00 PM
yfz350guy
K5 Blazer
Dec 11, 2010 1:39 AM
EvansBlue
Mar 18, 2010 8:13 AM
