K5 Blazer 1969-1994
Platform: Truck, GMT 400
Backfiring problem
Old Nov 22, 2012 | 1:32 PM
93k5350's Avatar
Default Backfiring problem
So i jsut bought a 93 k5 with an auto 350 picked it up ran beautiful. Went to the gas station filled it up about ten minutes later it started backfiring and loading up ??? i pulled over truck died started up and idles fine no backfiring or loading up this is the TBI setup i changed the plugs cap rotor ran startron through it and still no better...after that i hollowed the cat out "no emmision" still no better anyone have any ideas on what my problem might be ?
Old Nov 22, 2012 | 2:01 PM
kevinkpk's Avatar
Is it blowing any black smoke, or anything?
Old Nov 22, 2012 | 8:31 PM
93k5350's Avatar
No smoke no head leak nothing ?? I was told it might be the ambient air temp sensor located by the upper radiator hose at the thermostat housing neck ? it was about 50 degrees today and it ran horrible i just got in it to go to the store and its low 30's and it ran better ? i changed the plugs in it yesterday and i was told that maybe when i took the old plugs out carbon build up broke loose and got caught in a valve ?
Old Nov 22, 2012 | 9:19 PM
kevinkpk's Avatar
[QUOTE=93k5350;233454]No smoke no head leak nothing ?? I was told it might be the ambient air temp sensor located by the upper radiator hose at the thermostat housing neck ? it was about 50 degrees today and it ran horrible i just got in it to go to the store and its low 30's and it ran better ? i changed the plugs in it yesterday and i was told that maybe when i took the old plugs out carbon build up broke loose and got caught in a valve ?[/QUOTE]
No, if it were carboned up, you can run the crap out of it, hi rpm, then you should see black smoke. The old carbon trick with a carbed engine was high idle and push tranny fluid through it to break up the carbon. If the plugs were fouled, that will tell you if it is fuel, detonation, or whatever. What did the plugs look like?
c62nt62
Sep 25, 2007 7:05 PM
An89Chevy
Jun 30, 2007 8:30 AM
thebourbonpeasant
Jun 11, 2007 10:44 AM
infamous
Jan 11, 2007 4:09 PM
