K5 Blazer 1969-1994
Platform: Truck, GMT 400
Code 42 EST Problem 1991 R1500
Old Aug 7, 2021 | 9:44 AM
Parker762's Avatar
Default Code 42 EST Problem 1991 R1500
I was messing around with the distributor And unplugged one set of wires out of the back of that ICM and tried to start it and nothing happened so I plugged it back in. I removed the other plug-in on the I CM and tried to start it and then nothing as well. After that it started showing a code 42. Since then I have replaced the Distributor. I ran diagnostics using this that I found on the Internet:
http://www.fieros.de/en/v6help/code42.html
I have 500 ohms when testing the 423 wires
It led me to the ICM witch I replaced and still shows code 42.
I had the test light with the 424 tan/black wire lighting up with the 12v test light.
any ideas?
Old Aug 8, 2021 | 7:23 AM
Was there a problem that caused you to start unplugging these wires? Check these sets of wires to make sure that one of them didn't come loose therefore making a bad connection.
Ammo Pete
Mar 30, 2021 12:16 PM
thomas caspary
Camaro
Jun 14, 2019 1:59 PM
shetluck
May 30, 2013 6:58 PM
Peter M
Oct 3, 2010 10:25 PM
6in tahoe
Apr 18, 2010 10:40 PM
