K5 Blazer 1969-1994
Platform: Truck, GMT 400
Gearing quandry
Old Dec 4, 2014 | 12:17 PM
prospector1849's Avatar
Default Gearing quandry
Currently I have a 1988 C3500 with 454 and TH400 tranny dually.
I use to own a 1962 International p/up.
The low "Granny" gear was amazing in that truck..I could put in 1st and put cinder-block on gas pedal and get out of truck and walk along side of it (if I slowed down so truck could keep up).
Also like the International, this truck seems to sound like it needs another higher gear or 2 maby.
So...
Is there a way I can get the best of both worlds and get my "granny" gear back and have a lower RPM top gear for highway driving and fuel savings?
I do alot of open desert driving ( the need for a "granny") but coming from northern Calif and going to S. Cal or Arizona, the fuel bill is killin me.
Thanks in advance.
Old Dec 9, 2014 | 12:39 PM
nauticstar87's Avatar
Could swap in a 5-speed manual with a granny. Should be relatively plentiful, and its not to difficult of a swap. With a 454, good luck improving the fuel mileage no matter what you do.
Mark_MS
Jan 29, 2018 7:10 PM
86yota
Nov 11, 2008 12:12 PM
adam
Sep 17, 2007 9:56 PM
3rdday
Jul 2, 2007 4:58 PM
3rdday
Jun 30, 2007 4:37 PM
