K5 Blazer 1969-1994
Platform: Truck, GMT 400
Mini wire fire
Old Aug 25, 2022 | 10:24 PM
aviodont's Avatar
Default Mini wire fire
I have an 83 K5 for the last 9 years. I don’t use it often and it is parked in the driveway. To keep the battery from discharging, I disconnect both cables from the terminals and reconnect them every few months to start her up.
the last time I began this procedure, as soon as I connected the last battery cable, smoke started appearing from something on the firewall. I immediately disconnected the cables to prevent a fire. The keys were not in the ignition at any time and the headlights were not on.
after getting a fire extinguisher out of the house, I repeated the procedure and this time there was no fire/smoke. But the engine would not crank at all once the key was turned. No clicks.
I want to figure out what the problem may be. Or maybe I should say my teenage boys are also keenly wanting to figure out what the problem is.
pictures attached. Any thoughts?
Ianmac
1988 - 1998 (GMT400)
21
Mar 22, 2020 11:34 AM
karthur8
Jan 5, 2020 8:22 AM
William do
Colorado
Oct 28, 2019 10:59 PM
janevo596
Nov 2, 2015 6:38 AM
w002mia
Feb 13, 2013 8:48 AM
