K5 Blazer 1969-1994
Platform: Truck, GMT 400
Something Killing my fuel pump
Old Mar 29, 2020 | 8:35 AM
XAQSHNR's Avatar
Default Something Killing my fuel pump
Hey everybody,
Having an issue with my 90' K-5. something is killing the fuel pump. Had it fixed....week later....fuel pump not working.....Had it tested, Bad fuel pump. So we put it another one, lasted about 6 months....Turned the key......did not hear fuel pump cutting on....Truck won't crank. If I replace fuel pump again....works for a little while then nothing. Any help or direction would be great.....What would cause fuel pumps to keep failing???
Thanks in advance
Old Mar 29, 2020 | 9:12 AM
Little Bear's Avatar
Had this issue in a 96 Burb, everyone that died quick was aftermarket brands, spent the money on an AC Delco pump and the problem went away.
Old Mar 29, 2020 | 9:14 AM
kevinkpk's Avatar
Originally Posted by XAQSHNR
Hey everybody,
Thanks in advance
The fuel in the tank also cools the pump. It is possible running the tank low will cause it to overheat, also cheap after market pumps don't last.
Old Mar 29, 2020 | 10:19 AM
Only use Delco or Delphi pumps!!
Old Mar 29, 2020 | 2:18 PM
did you change the filter too?
Old Mar 29, 2020 | 5:16 PM
XAQSHNR's Avatar
Yes I changed fuel filter
patlsan
Sep 22, 2014 11:44 PM
Khazlett
Jan 19, 2010 1:29 PM
LHHEMS
Dec 28, 2007 7:18 AM
Enstar
13
Jun 22, 2007 10:36 PM
