K5 Blazer 1969-1994
Platform: Truck, GMT 400
Tbi rebuild
Old Jan 3, 2025 | 2:07 PM
Rsmetana2@gmail.com's Avatar
Default Tbi rebuild
What is the plastic/rubber grommet on the wires for the injector pigtails? Not the insulators on the injector plugs but the grommet that slides into the tbi housing. I can’t find a replacement anywhere. If y’all know where i can get one let me know. I’ve got a glob of high temp caulk on it for now but that ain’t my style.
Old Jan 4, 2025 | 12:16 PM
Welcome from Florida. Most hardware stores, Amazon, Ebay, etc. sell grommets. I have bought them from Home Depot, just have to match the style and size.
Old Jan 15, 2025 | 10:32 PM
Default Tbi injector wire harness grommet.
hi. Thank you. To be more specific. I chose the word grommet as the best example of what i could compare the piece I’m searching for to. It’s actually a small molded square block shaped piece that slides into the front of the tb. It has the injector wires going through it. It got pretty well vaporized when i grabbed it with needle nose to slide it out. I could find a small block of rubber and make my own but i assume the real deal is out there somewhere. Any ideas on locating the actual part?
Old Jan 16, 2025 | 8:47 AM
Maybe you can use some silicone to seal and hold the wires in.
metal24915
Feb 27, 2016 9:34 AM
Rado95
Aug 7, 2013 2:51 PM
VicJac
Aug 2, 2013 6:55 PM
VicJac
Jul 31, 2013 5:53 PM
boxchevy
Sep 19, 2011 10:34 PM
