K5 Blazer 1969-1994
Platform: Truck, GMT 400
WOT problems
Old Apr 25, 2012 | 11:27 AM
87blazink5's Avatar
Exclamation WOT problems
hi i have this 87 k5 with a carbed 350 (quadrajet) bored .60 over rv cam 882 heads edlebrock performer intake. im havein problems goin up hills and wot likes to suck the fuel bowl dry i have a electric fuel pump and regulator set at 5psi and the fuel pumpm pushes 30gph and i was reading that the block mount pushes around 50gph could that be my problem? need nemore info just ask and thank you
Old Apr 25, 2012 | 4:47 PM
CS057's Avatar
With an upgraded motor it doesn't sound like a good idea to be running a pump that is running such low numbers. I would think you need 60gph or more, along with that you could probably up the pressure another PSI. Hope someone can give you a bit more specific advice.
With regards, Cyrus
99yukon
Apr 11, 2021 8:38 AM
bobehud
Sep 17, 2011 7:00 AM
carton30643
Aug 19, 2009 10:10 PM
jmillie
Feb 17, 2009 7:04 PM
rvaughn801
Jan 6, 2008 10:22 AM
