Chevrolet Malibu
'03 Malibu fuel pump/fails to start.
Old Jun 2, 2011 | 7:54 AM
ronnyvous1's Avatar
Default '03 Malibu fuel pump/fails to start.
History on the issue: About 2 years ago, car wouldn't start. Replaced fuel pump relay, no better so we replaced the pump with a used one. About 2 months later the car wouldn't start, I swapped the relay back to the original one and it worked fine for the last year and a half. Tuesday, after a full day of use, no start again. Pulled the relay and replaced with a new one, no good, so pulled the fuel pump and replaced it. I checked the one from the car with 12VDC and it works as well, also replaced filter. Misted gasoline into the air intake and it fires and runs until the fuel is exhausted. When cranking long term it tries to fire. No fuel pressure? No power to pump? I will have to slide under and have someone turn on ignition to see if I can hear the pump. Where would I check to see if there is voltage to the pump, or where would the DC voltage get interrupted so that the pump doesn't kick in? Is there a fuel pressure sensor that could coause this, can the system become air bound, or have a leak that would cause the pressure to drop? Thanks.
Old Jun 2, 2011 | 10:57 AM
ronnyvous1's Avatar
Follow up: Got back under the car, fuel pump actuates when the key is turned on. Still no start, no codes indicated. I don't have a fuel pressure guage, thinking about trying the old "unplug the line and see if it squirts" method. If there appears to be flow from the pump, what is there ahead that could be an issue? Hit the line with a low pressure shot of air to see if it clears? Sure could use some help on this one, gang, cannot afford to play at the dealers, and I don't want to keep throwing money at it until I find the right thing. We need this car back up and running.
Old Jun 2, 2011 | 5:34 PM
EinST's Avatar
Welcome to the forum. You probably don't want to hear it but you need to start with the fuel pressure (41-47 psi with KOEO). Based on the history, I suspect it may be the fuel pump or fuel pressure regulator.
Old Jun 4, 2011 | 1:56 PM
ronnyvous1's Avatar
Update: Appears to be the Passlock system. Ten minutes with the key on, switch off and then start, back in business. Looks like I will be researching the bypass mod for this since I really can't drop the money for a new switch/sensor.
DrDon
Dec 31, 2014 4:41 PM
codeman061988
May 20, 2014 11:15 AM
Hunt4X4
Apr 8, 2011 10:29 PM
DUNTOV
Nov 13, 2007 11:28 AM
surprised
Oct 10, 2006 1:00 AM
