1999 Malibu shuts off after slowing down from high speed
Help, my car starts out running fine at 30 mph. It runs great on the expressway, But when I leave the expressway, my car shuts down ( as if it is out of gas). When I pull over and restart the car, it will go a short distance and do it again. Today when it started to shut down, I pulled into a parking lot and while the car was in park, I could hear the fuel pump making a whining noise. I made it home but the car stalled out a few times. My mechanic replaced the fuel filter which he said was clogged 2 days ago. He test drove it and said that it was ok. Does anyone have any suggestions? My car is my only means of transportation. Would it be a good idea to take it to a Chevy dealer?
Sounds like the EGR may have a lot of carbon build up in it. When your on the highway, the EGR is open allow exhaust gases to be recirculated. When you're at an idle, it should be closed.If a piece of carbon gets caught in the pintle, it won't allow to close all the way, so when you slow down it makes the car stall. If you can get it to idle while this is happening, use the handle of a screwdriver, and tap the EGR a few times to see if it clears up
When the car shuts down, the check engine light is not on and you can hear the fuel pump. Do you still think it might be the EGR?
The car runs ok then gets a slight hesistation. You have to push on the gas pedal to keep the car going. Then the car stalls. This happens even more in warm weather.
Pull the EGR off and check for a carbon build-up. one way to test if it is that or not is to unplug it when the engine is running smoothly, take it on the highway, then see if it still stalls when you get off. By unplugging it, you are preventing it from opening and possibly getting a piece of carbon in there. The check engine light will be on the whole time it is unplugged, but will not harm anything.
It does seem funny that it runs fine at low speeds initally which would mean the EGR would be more in play. Then it starts stalling after coming off higher speeds makes me wonder if it is the EGR and not something else like a TPS or vacuum issue.
aubiexx
December 1st, 2013 7:58 AM
flynhayn
July 22nd, 2011 9:35 AM
Typerod
January 12th, 2011 6:59 PM
