Chevrolet Malibu
2000 Malibu power window wiring
Old Jul 14, 2009 | 11:40 AM
stepdls's Avatar
Cool 2000 Malibu power window wiring
I replaced the motor on the drivers side and it will only go down but not up. I also replaced the switch and the same problem. It does look like someone has worked on the wiring so I need to find a wiring diagram for the power window on the drivers side switch. I need to verify the wires are all correct. Where would I find a wiring diagram?
Old Jul 14, 2009 | 2:16 PM
hfb1957's Avatar
I googled my radio speaker wiring diagram and found most of the diagrams for a 2003 model
Old Jul 14, 2009 | 2:56 PM
Chevmastertech's Avatar
You have a broken feed wire(s) in between the door and the body. Due to opening and closing the door and the wiring harness getting brittle, the wiers break. Peel back the boot or get inside the door and gently tug on the wires in the harness. I'm pretty sure you will find one broken in two. Repair as nessacary.
Old Jul 15, 2009 | 12:19 PM
stepdls's Avatar
Angry
I have been looking for a broken wire but have not found one yet. All the other windows work so I tried wiring up the driver side window to one of the other windows (front passenger side) and it works when I do that.
Old Jul 15, 2009 | 12:47 PM
stepdls's Avatar
Talking
Ok it's fixed now! I am not sure how this happened but the two dark blue wires on the connector had been switched. I switched them back and all the windows work correctly now.
saimer
Jun 26, 2019 5:24 PM
justin69
Feb 28, 2015 2:54 PM
LennyButch
Dec 1, 2013 8:17 PM
davbell22602
Mar 10, 2010 8:36 PM
phillydogg
Sep 17, 2007 8:26 PM
