Chevrolet Malibu
2001 Malibu LS Vent Blower Problems
Old Jan 26, 2007 | 3:39 AM
xtravis's Avatar
Default 2001 Malibu LS Vent Blower Problems
Over the last 3 weeks or so I have had problems with the vent blowers working at the normaly rapid speed when set to 5 on the dial, but then wait (sometimes a few seconds, or minutes) and it winds down and is barely pushing air at all!When it beings to slow downit sounds like the blower is strugging andbegins making a whining noise. I was thinking about up and replacing it butI was just wondering if anyone had any suggestions!
Thanks!
Old Jan 26, 2007 | 10:43 AM
gmdinusa's Avatar
Default RE: 2001 Malibu LS Vent Blower Problems
I had a similar problem but fixed it by changing the blower resistor. Not that much fun to get to under the glovebox, though.
I miss the days when the blower was in the firewall
Old Jan 26, 2007 | 1:15 PM
golfer's Avatar
Usually the problems with the "resistors" is they cause the fan not to work at all at certain speeds ( usually the lower ).
From the description of the blower slowing down and making noise is likely due to the motor itself or some obstruction.
Old Jan 26, 2007 | 6:42 PM
xtravis's Avatar
I went to Advance Auto today just to see what they would tell me and I was told I should most likely just replace the blower motor which I plan to do within a week or two. Thanks for the help!
Old Jan 28, 2007 | 6:35 PM
gmdinusa's Avatar
When I did it, I bought a blower first AND then went on to replace it. Once I got under there, I found some dirt and leaves, etc. The contacts seemed dirty, too.
I tested the blower motor out of the car with a full 12 volts (same as speed 5) and it ran perfectly.
Then I tested the resistor with a meter and there were some burned sections.
My advice would be to test it first. Then go to the store. A resistor is cheaper.
Old Mar 4, 2013 | 11:56 PM
Malibu2001LS's Avatar
Yes, I changed the resistor 2 days ago and was around $20. All 5 speeds back.
WOODSTOCK6978
Dec 18, 2020 2:37 PM
Woodenhead
Jul 15, 2014 10:13 AM
rknash
Sep 9, 2012 7:09 AM
angus75
Jun 16, 2012 2:57 PM
ssrobzoom
Feb 14, 2010 11:34 AM
