Chevrolet Malibu
2001 Malibu won't start
Old Feb 12, 2011 | 7:13 PM
arcturusmine's Avatar
Default 2001 Malibu won't start
I have a 2001 Malibu that will not start.
I will fire if given a sniff of WD-40 in the intake.
If I take the fuel cap off, I can here the pump run when my son turns the ignition on.
We tapped on the tank.
We switched diffrent relays around with no success.
There is pressure at the rail. We bled it off with a screwdriver, hit the switch, and there was pressure there again.
We intially thought it was a frozen fuel line as I had 1/4 tank of gas and the temp was -25 when I tried to start it. But it was 40 above today and no further success.
Any ideas what it could be?
Old Feb 12, 2011 | 8:09 PM
jimmydow1's Avatar
try putting a long screwdriver on each fuel infector to see if they are working (you should hear a click as they open and close) while you turn the engine over. or you can test them with a voltmeter or test light
Old Feb 12, 2011 | 8:41 PM
Thanks
GOt it figured out. It was the passlock system.
Didn't see the light going off until it was dark and read about that giving problems.
ZChevyAK
Nov 13, 2015 6:45 PM
James Brooks
Dec 19, 2013 10:55 PM
kong
Feb 5, 2010 4:17 PM
bracca
Jul 12, 2009 6:14 PM
FamilyOf5
Jun 11, 2008 2:56 PM
