Chevrolet Malibu
2002 Chev Malibu issue with tripping fuse when turn on a/c or heater
Old Jun 10, 2018 | 8:02 PM
Mkinder18's Avatar
Default 2002 Chev Malibu issue with tripping fuse when turn on a/c or heater
I changed out the a/c heater blow motor and blower resistor with same result. It is fuse 37. I'm frustrated. Any ideas?
Thanks. Mike
Old Jun 11, 2018 | 1:17 AM
fuse 37 is for the a.c compressor clutch and bcm ignition 1 circuit not the blower motor and resistor. what do you turn on that blows the fuse? if its only the a.c....check the compressor clutch and compressor
Old Jun 12, 2018 | 8:26 AM
Mkinder18's Avatar
Thanks. Mike
Actually, the fuse blows whether it is the a/c or heater is turned on. The blower fan does continue to run though.
Thanks.
