Chevrolet Malibu
2002 Hesitates
Old Mar 18, 2008 | 7:29 PM
Shayughul's Avatar
Default 2002 Hesitates
I have a 2002 with about 115K on it. This weekend I did the plugs, wires, and caps. I have noticed thou that I seem to have lost some power. I verified that they are all correct and I have the right plugs and all. I don't get a check engine light. But it seem to hesitate when I attempt to accelerate. I also noticed it seems to not want to shift. It has a hard time accelerating up hill.
I was hoping somebody might point me in the right direction on how to get this corrected or where to look. Are there any common vacuum issues with this that might cause the Automatic Trans to not want to shift?
TIA
Old Mar 27, 2008 | 8:10 AM
Shayughul's Avatar
Default RE: 2002 Hesitates
So I have no replaced the plugs, wires, caps, air filter, fuel filter, EGR Valve and have cleaned the Air Intake Manifold, the Air Intake Control and everything else I could think of. In a desperate measure i have drilled holes into the Cat to remove that from the equation and still nothing.
The car still hesitates badly when accelerating from 20 to 40. If I stomp on the gas it will down shift and lose all power until I let off and it finds the proper gear again. The only thing I am not 100% sure on is I used Bosch Platinum Plugs when I did this and they have the 4 arms on it that I cannot gap. Is it possible that the engine just does not like these plugs? Could that be causing all this? I am going to invest in some $2 plugs tonight and put them in and see what happens.
No help at all out there?
Thanks
Old Mar 27, 2008 | 5:33 PM
shawnvw's Avatar
Banned
If it only happened after you did the work, I would say it is something that you did. Some might say its coincidence, but i don't believe in that.
It really sounds like a couple wires are mixed up, but if you are 100% sure they are right, then i would go after the plugs as you say. When you say that you did caps....what does that refer to?
Old Mar 27, 2008 | 8:48 PM
Shayughul's Avatar
Thanks for the reply. I meant the coil packs I think they are called on these.....basically the 3 distributor caps. So I put in some normal plugs and things seem to be a little better. It still hesitates some and will not accelerate uphill at all. It is much much better now thou. Will drive it around tomorrow and see how it does.
Old Mar 27, 2008 | 9:23 PM
shawnvw's Avatar
Banned
If its still doing it, check for spark on all cylinders, If there is spark, trying changing the coils back to the old ones. There mnight be one coil failing under load
monte99
Mar 18, 2010 8:29 PM
mmiller0
Aug 2, 2009 8:57 PM
02cavagrn
Mar 11, 2008 3:28 PM
TXAngel06
Sep 18, 2007 8:36 AM
sparrow
Sep 17, 2006 1:48 AM
