Chevrolet Malibu
2003 Malibu 3.1L vacuum line
Old Nov 18, 2019 | 11:51 AM
Ben1112's Avatar
Default 2003 Malibu 3.1L vacuum line
Hello,
My 2003 Malibu LS 3.1L was running rough at idle. The code indicated a lean condition. Utilizing the fuel trims I concluded it was likely a vacuum leak.
i found one vacuum line that had a piece of broken rubber on it but can’t find where the other end connects. Wondering if it is supposed to be plugged. One diagram doesn’t show it but others indicate it as to accessories.
when I plug it the idle is perfect but the fuel trims at high rpm indicate a rich condition. Do these take awhile to normalize? Is this supposed to be capped? Thanks for any help.
Located right in front of alternator.
Old Nov 18, 2019 | 5:20 PM
oilcanhenry's Avatar
Originally Posted by Ben1112
Hello,
If its affecting your fuel trim it must plug into something. I cant see from the picture which hose you speak of. Can you elaborate?
Old Nov 18, 2019 | 5:33 PM
Ben1112's Avatar
It is the little metal coupling right in front of the alternator. It doesn’t have a hose on it, it just had a small piece of broken rubber on it.
Old Nov 18, 2019 | 10:36 PM
looks like the main vacuum source. Typically it goes to a checkvalve and spherical reservoir around the passenger wheel arch, before going through the firewall to the HVAC controls inside. Sometime there' a sticker with vacuuum routing diagram right under the hood.
Old Nov 19, 2019 | 11:08 AM
Ben1112's Avatar
There is a schematic or the lines on the strut tower but this port is not highlighted. That is why I’m wondering if it supposed to be capped. Other schematics for similar vehicles refer to it as “To Accesory”.
Old Nov 19, 2019 | 11:44 AM
Does your vent selector work?
Old Nov 19, 2019 | 12:02 PM
Ben1112's Avatar
Yes but it sounds like a puff of air is emitted when switching between them.
Old Nov 19, 2019 | 3:48 PM
If it doesn't seem to go to anything, but it has vacuum then yes you'll need to cap it, as it will allow unfiltered air into your engine
Old Nov 19, 2019 | 4:18 PM
Ben1112's Avatar
Thanks for the help. I will cap it and see how it goes. It sounds much better capped and doesn’t chug (can feel it) but I’m concerned about the fuel trims indicating its running rich.
Old Nov 19, 2019 | 5:47 PM
kevinkpk's Avatar
mountainmanjoe
It is. The op needs to trace the tubing back, and reinstall it. I can't believe it will even run.
