Chevrolet Malibu
2004 LT will not start
Old Feb 14, 2010 | 9:37 PM
indy's Avatar
Default 2004 LT will not start
A little background. Went to store came out and car would not start. got lights and radio and dash lights, when the key is turned to start everything goes dead. Tried a new Battery, pulled the starter took it to Oreilys to be tested and it passed. Connections are all clean and tight. Even tried the 10min drill for the theft. Could the BCM be bad?
Old Feb 14, 2010 | 10:19 PM
2004MaxxLT's Avatar
I had the same issue, it was the starter. I took the car to a Chevy dealership and they confirmed the starter was bad, even though it worked fine on the test rack at Murray's/O'Reily's.
As a test, try hitting / tapping the starter a few times with a hammer while having the key turned to the start position. If the starter is bad, it still may fire up when hit.
Old Feb 16, 2010 | 9:16 PM
indy's Avatar
Default 2004 Lt will not start
Connected a hot wire to the battery from starter and it cranked the engine. Starter probably good swapped starter relay didn't help, ignition switch or neutral safety switch?
attycda
Dec 27, 2021 12:34 PM
Sparky Sparks
Jan 23, 2019 10:53 AM
Xerklite
Apr 27, 2013 9:14 AM
jasonphoto01
Nov 8, 2009 4:28 PM
