Chevrolet Malibu
2005 Classic - Vibration at idle, engine runs great
Old Mar 13, 2010 | 4:59 PM
jlmnjem's Avatar
Default 2005 Classic - Vibration at idle, engine runs great
I have a recently acquired 2005 Malibu Classic with the 2.2 Ecotech. When I put the car in gear and let it idle, there is a pronounced vibration. I spent all day today removing and reinstalling the side engine and transaxle mounts (in front and rear of the engine compartment), but the rubber in both of them was fine. I didn't remove the front engine mount (on the PS of the engine compartment), but I can place my hand on the inner PS fender apron area where that engine mount attaches and I feel no vibration in the chassis while the engine is vibrating in drive. I can see the rubber in that mount and it appears to be intact without significant movement. I've checked DTC's and none are present. The car accelerates very smoothly, and the vibration goes away immediately when I slip the transmission into neutral. Any ideas?
Old Mar 14, 2010 | 10:32 PM
kizzelwhix's Avatar
does it do the same in both drive and reverse, or just drive?
Old Mar 27, 2010 | 9:06 AM
jlmnjem's Avatar
Both drive and reverse, but probably a little more pronounced in drive.
Old Apr 17, 2014 | 1:49 PM
Frisbie1's Avatar
New User
Awaiting E-mail Confirmation
Did you ever find out what your problem was with the vibration? I have an '05 Malibu Classic with the same exact problem.
Old Jan 18, 2015 | 4:30 PM
los2005's Avatar
Default same issue
Was just wondering if anyone found out what that problem was. I'm having the same issue
Old Aug 24, 2021 | 6:38 AM
Clydej1885's Avatar
Default Anyone figure it out?
just wondering if you figured the issue out. I'm having the same problem. thanks
pjbialas
Jun 4, 2012 8:36 PM
greatwhite99
Aug 27, 2011 4:00 PM
eisterd
Apr 20, 2010 8:52 AM
demian5
Mar 6, 2010 11:09 PM
ondagaskiknass
Jul 1, 2007 1:59 PM
