Chevrolet Malibu
2006 Malibu Brake Light Problem
Old Apr 27, 2012 | 1:49 PM
  #21
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Travis Truesdale,
It's possible that there is a connection issue. I assume the fuses and bulbs have been checked. If you would like, I can find other service centers in your area for you, if you provide your zip code.
Please keep us posted.
Louis
GM Customer Service
Old Apr 27, 2012 | 3:49 PM
  #22
Travis Truesdale's Avatar
Default lights
well it is my understanding that on the 06 there isnt a fuse for brake lights its a direct controlled feed from the bcm. I have searched high and low for a fuse. Every Bulb on the car has been replaced all the way to interior light.
Old Apr 28, 2012 | 1:30 PM
  #23
EinST's Avatar
If yours is a 2006, yes, the BCM supplies the power to the individual lamp filaments. If it worked before the repair (on constantly, was it the problem?), something got damaged during the repair. It's rather easy to damage the terminals by cranking down on the connector retaining bolts.
Old Oct 25, 2012 | 9:50 AM
  #24
Purified Daughter's Avatar
my brake lights on my 2006 chevy malibu LT is out. A mechanic says it may be a module, but was not certain. When I press the brakes they will not come on at all.
Last yr I had the total opposite. They were acting in reverse order, when i hit the brakes they went off and when i removed my feet off brakes they came on. Well, in december, I got a new brake lamp switch installed. Can you tell me what this could be? What is a module?
Old Oct 26, 2012 | 5:53 AM
  #25
malibumike's Avatar
I had the same problem i replaced thr brake switch and everything finally i gave up and took it to the dealer. They told me some switches must be programed or thay wonnt work so he tried reprogramming it after that didnt work he pulled the dash apart and found a loose conection after he retightened it ive never had that problem again knock on wood lol i hope this helps
Old Oct 26, 2012 | 1:16 PM
  #26
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Purified Daughter,
It may be module related, however, a relearn may be in order too. This is just a suggestion, not a diagnosis. I encourage you to consult with your technician for an official diagnosis.
If you have additional questions or concerns, please feel free to contact me privately.
Louis
GM Customer Service
Old Aug 14, 2013 | 12:25 PM
  #27
halfman7176's Avatar
New User
Awaiting E-mail Confirmation
Default cruise control switch
Originally Posted by kdcarman
I have a 2006 Malibu with a strange brake light problem.
The brake lights react in reverse order.
When the brake pedal is NOT pressed, the brake lights are on.
When the brake pedal is pressed, the brake lights turn off.
Any suggestions where to look?
Thanks
the cruise conreol awitch was the issue when my malibu was doint that exact thing
bdowler227
Dec 19, 2014 9:02 PM
blacey
Apr 19, 2014 11:05 AM
Bambam2264
Sep 13, 2012 6:43 AM
ericmckinney
Uplander
Oct 14, 2011 10:35 PM
beckya99
Jul 12, 2011 12:29 PM
