2006 Malibu radio removal
The cd player in my wifes car is jammed. I need to know how i can remove the unit from the dash. Everything is factory and the player is a single disc player. Any tips on solving this problem would be great.
its gonna be tricky to find directions on how to do remove that radio for free because its so new, I googled a bunch of phrases to do with removal of your radio and found a site that sell a 40 step instruction sheetfor a few bucks, I didn't want to post the site because I'm not sure this forum allows that, but it out there.....Good Luck.
[ol]Remove the instrument panel(I/P) left trim panels. Refer to Instrument Panel Trim Panel Replacement - Left Side .
Remove the I/P right trim panels. Refer to Instrument Panel Trim Panel Replacement - Right Side .
Remove the I/P compartment. Refer to Instrument Panel Compartment Replacement .
Remove the knee bolster. Refer to Knee Bolster Replacement .
Important:The I/P center trim bezel is painted and can be damaged. Pull on the bottom of the bezel to disengage the lower clips first or damage to the HVAC control module could occur.
Remove the I/P center trim bezel.
Remove the hazard switch. Refer to Hazard Warning Switch Replacement in Lighting Systems. [/ol]
[ol]Remove the instrument panel (I/P) center trim panel. Refer to Instrument Panel Center Trim Panel Replacement .
Remove the HVAC control module. Refer to HVAC Control Module Replacement .
Remove the radio screws.
Remove the radio.
Remove the radio wire harness connector.
Remove the antenna cable at the radio. [/ol]
Remove the radio.
adamant
Feb 15, 2009 8:49 AM
DaBluBu
Mar 13, 2008 6:15 PM
