Chevrolet Malibu
2008 Malibu - 100% dissatisfaction
Old Nov 23, 2007 | 6:23 PM
Skvitt's Avatar
Default 2008 Malibu - 100% dissatisfaction
Picked brand new 2008 Malibu from a dealer on Nov 20, 3 days later 100% dissatisfied with the new GMs 6-speed automatic, it is a piece of junk.
Nature of the problem: in the speed range between 10 - 30 mph in the slow traffic where you speed up alittle, than cost, than speed up again every time I touch the gas pedal there is a distinctkick in the drivetrain, which becomes annoying after a few times. Same thing happens when you make a turn and then try to speed up.Went to the dealer and he says that it is the way it normally works. I own a 2000 Malibu as well, just took it for the ride to compare, and what a smooth ride, even my 1993 GMC Safari van, which I traded in for this new piece of junk, ran smoother. Overall Ilike the styling (althoug workmanship is ofa typical for GM quality). GM says that it wants to compete with Camry and Accord with this new Malibu, aha, good luck.
So guys, if anyone conciders this one as a next wehicle - take it for a good test drive, or better rent it for a few days. I regret that I didn't.
Old Nov 23, 2007 | 9:59 PM
EvansBlue's Avatar
Default RE: 2008 Malibu - 100% dissatisfaction
I'm sure that just because you have had bad experiences with it so far doesn't mean everyone else has. It sounds more like you have a problem with the drivetrain. I'd take it back to the dealer and complain about the drivetrain and tell them to fix the kick in it. The ride quality you can't do much about except to get rid of the factory tires in favor of some Michelins or even BFGoodrichs.
Old Nov 24, 2007 | 8:17 AM
Skvitt's Avatar
There is nothing wrong with the ride overall, in fact it is the quietest and smoothest car I ever owned, but when it comes to conditions described above, that kick cancelles all snmoothiness.
I've taken it back to dealer, in fact we test drove a similar one, the kick was there, although not as pronounced as on mine, maybe because that car was cold. But service manager stated that it is the normal operation for this transmission and it is not a problem. I am a lifelong GM owner, but this car with the price tag of $33,000 CDN may end my loyalty. I'm still hesitatiing of what to do, I like the vehicle overall.
Old Nov 24, 2007 | 10:46 AM
the_vigilante's Avatar
i have a 2007 malibu and wish i waited for the 2008 model. it looks far better then the '07.
i have noticed that tranny kickback with my 2007 malibu ls and i thought it was just my driving that was causing it. Its when im slowing down to a redlight but turns green so i go to speed up a bit and u feel a light kick from the car.
Old Nov 24, 2007 | 11:49 AM
MalibuMaxxSS's Avatar
The kick your feeling is because it uses a electronic throttle control, took mesome getting used to, basically you cant gradually speed up I find.......when you try it lurches forward.........nothing you can do about it. and everyone uses the same setup now so they should all feel the same......
Old Nov 24, 2007 | 3:24 PM
EvansBlue's Avatar
^ yeah X2
The ETC can be adjusted with a power programmer if they make one for it.
Old Nov 24, 2007 | 4:04 PM
oh ok. good to know. i was afraid it would lead to tranny problems
Old Nov 24, 2007 | 7:29 PM
tahoe07's Avatar
Most vehicles adjust to the driver as you put mileage on. The computer will go from factory settings to one thatmatches your driving. Give the thing some time and hopefully the shift/kick willimprove.
Old Nov 27, 2007 | 12:36 PM
mkaresh's Avatar
Banned
They might also update the firmware for the transmission. They went through a number of software revisions with the same transmission in the Lambdas before developing one that everyone seems to be very happy with.
The same powertrain is used in the Saturn Aura and Pontiac G6. You might searching a forum for those cars to see if anyone has had a similar complaint, and if anything was done about it.
Good forum for the Aura: http://www.saturnfans.com
Old Nov 28, 2007 | 8:02 PM
Skvitt's Avatar
Almost got used to it. But tonight got into a havy traffic, was going 10-15 mph for an hour. That transmiision drove me crasy, it looks like it acts on its own in that speed range, shifting up and down with no reasons, and each shift is acompanied with that kick, which is more and more pronounced. It is frustrating. Going to see the dealer tomorrow again.
