Chevrolet Malibu
98 Malibu One click wont start
Old Dec 7, 2016 | 1:33 AM
Brian Wheeler's Avatar
Default 98 Malibu One click wont start
Hey guys I've been working on my car for a day and a half and have this information on what i ve done, still nothing is happening.
I've gotten the starter tested and it works, I have also used the screwdriver trick and hear the same wuring noise but hear no click or spinning. I've cleaned the engine block and chassi grounds and cleaned all of the connection for the starter. I don't get full illumination of my dash board just battery light and check engine light when i turn it to the on position. the ignition switch was replaced six months ago. some of the fuses looked worn but were connected. I can turn the crank by hand. Im at a loss. What do I do? Its my only car and have had to leave a town away in a parking lot and try to fix it after work. thanks for cheking this out guys.
Old Dec 7, 2016 | 4:41 AM
You don't mention the battery. Did you do a load test on the battery? Check both ends of the battery cables for looseness and corrosion. You may also have an alternator problem if the battery is dead.
Old Dec 7, 2016 | 8:45 AM
I still saw sparks when i went and checked the terminals, but today i will definitely get it checked. how does one test their alternator?
Old Dec 7, 2016 | 8:42 PM
An easy way to check it is with a volt meter. With the engine running put the probes of a volt meter on the battery terminals. If it is charging it should read around 14 volts. If it is not charging it will read 12 volts or less.
