Chevrolet Malibu
The air conditioner does not heat up
Old Oct 16, 2019 | 8:13 AM
Daniel Molokndov's Avatar
Default The air conditioner does not heat up
Hello,
My air conditioner in the car does not take out heat, it takes out air
Now I have two hoses cut off in the engine and that's probably the problem.
Image:
In addition, there is a connection in my opinion that they did not have a picture:
Deen
Old Oct 16, 2019 | 9:38 AM
Craig0320's Avatar
Looks like the heater core is bypassed. Most likely was leaking inside the cabin and previous owner bypassed it instead of fixing it. Not sure what you mean by your a/c is not heating up. You have a evaporator coil for the a/c and a heater core for the heat.
Old Oct 16, 2019 | 9:55 AM
Irish_alley's Avatar
I'm here for the party
this is why i left this one alone. technically the ac does remove heat from air which makes his statement true but i just didnt want to get into it and the pictures for some reason where making my head hurt
Old Oct 16, 2019 | 11:30 AM
Craig0320's Avatar
Lol. I almost didn't respond to it as well. But everyone has to learn sometime.
Old Oct 16, 2019 | 2:36 PM
So that's how I plugged the pipes back in. I turned on the air conditioner and he started to heat up. I did a number of tests to see that it only heats up in heating mode, I checked for fluidity, and tested engine heat to see that it did not affect the meter and at the moment everything was looking good.
How can you tell why the previous owner cut off the heating pipes?
Old Oct 17, 2019 | 11:13 AM
Craig0320's Avatar
You'll have water/antifreeze in the passenger floor board. The only reason to bypass a heater core is for it leaking. That's the only reason I can think of anyway.
John Makuk
May 19, 2019 10:56 AM
Duane Sapp
2014 - 2018 (GMT-K2)
Aug 2, 2018 7:14 PM
kmny
Sep 4, 2016 2:56 PM
HotSauce6226
Apr 10, 2009 4:32 PM
