Chevrolet Malibu
Cruise Control Issues
Old Mar 1, 2012 | 6:29 PM
Rashad Woods's Avatar
New User
Awaiting E-mail Confirmation
Default Cruise Control Issues
Evening
I have a 2008 Chevy Malibu and I've noticed that the cruise control seems to work when it feels like it. Anybody experience the same?
Thanks
http://www.yourwhip.com
Old Mar 1, 2012 | 7:45 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Rashad Woods,
It may be an issue with the body control module (BCM). You may want to take the vehicle in to be inspected by a certified technician for a more accurate diagnosis.
Louis
GM Customer Service
Old Mar 1, 2012 | 7:54 PM
New User
Any reason this would just start happening recently? It worked fine for the last 2.5 years
You belong http://www.yourwhip.com
Old Mar 1, 2012 | 10:49 PM
cleveland63b's Avatar
could be a couple things...wore out/stickings witches or BCM problems...hard to give you a good direction with it being intermittent best bet is taking it to a shop
Old Mar 1, 2012 | 10:56 PM
EinST's Avatar
The brake lights are on without the foot on the brake pedal, maybe? Do a web search for TSB #08-05-22-009 (currently up to revision #08-05-22-009C). Some shops will start with replacing the brake pedal position sensor and generally flop around which is patently the wrong way to go.
pcwilcox
Oct 21, 2013 11:00 AM
CoryWinburn
Oct 9, 2013 6:29 PM
chrishooch
Jan 2, 2013 9:03 PM
liljoe66
Aug 5, 2011 12:44 PM
kbridge234
Sep 4, 2008 10:03 AM
