Chevrolet Malibu
Disarming Airbag System
Old Aug 2, 2009 | 1:33 AM
exuL1B47's Avatar
Default Disarming Airbag System
Hello
Ref.
2005 Malibu Maxx, LS
I have to do some work around the dash board and panels:
Remove replace Multi Use light/turn signal switch
Remove/Replace/Secure radio
My question is: One: if I remove the Airbag fuse will that disarm the Airbag system and prevent from firing while I'm working around the dashboard or is it necessary to disconnect the battery?
Two: What are the consequences/ramifications to the on board computers of disconnecting the battery?
Three: If I use a "memory saver" and remove the Airbag fuse will that combination work to preserve the memory and prevent the Airbags from firing?
Thanks
Old Aug 2, 2009 | 6:53 AM
shawnvw's Avatar
Banned
just pull the 2 fuses, and wait for about 10 mins before starting to do any work and you should be fine
Old Aug 2, 2009 | 5:28 PM
exuL1B47's Avatar
Hi
Thanks for the reply and info. You state: " just pull the two fuses" my owners manual shows only one airbay fuse. Is there any other precautions one should use when pulling an airbag fuse? Your thoughts. Thanks.
Old Aug 3, 2009 | 8:16 AM
shawnvw's Avatar
Banned
There should be 2 fuses at the fuse panel in the center console.
Make sure th key is off, pull the fuses, wait for 10 mins, then go to work
Old Aug 3, 2009 | 10:05 AM
exuL1B47's Avatar
Shawn, Thanks
Mattman12
Mar 16, 2015 7:35 AM
surfandride
Jan 16, 2011 10:05 PM
SILVERAD01
Mar 17, 2009 9:30 PM
Slammed Birch
Dec 13, 2006 6:49 PM
wayner52
Jun 27, 2006 7:43 PM
