Chevrolet Malibu
Dome light problem
Old Sep 12, 2009 | 9:40 PM
c3014101's Avatar
Default Dome light problem
I have a 2006 Malibu. The doom light only can be turned on manually . what problem ? how to fix it ?
Old Sep 14, 2009 | 12:55 PM
ang4561's Avatar
If the '06 Malibu dome light is anything like the '05 G6 dome light (which I think they should be similiar), actually has a 3 positions. The left position is off, the middle position is doors, and the right position is on. Have you tried switching the switch to the middle position?
Old Sep 15, 2009 | 5:06 AM
c3014101's Avatar
already tried, switching to middle position does not work
Old Sep 16, 2009 | 7:40 AM
HotSauce6226's Avatar
Impala Super Moderator
Old Mar 24, 2014 | 4:10 PM
jaost's Avatar
I having the same problem. I think it's in the dome light switch, but i am having difficulty accessing it. Got the dome light cover off but I can't seem to remove the housing to access the switch.
Old Mar 24, 2014 | 4:49 PM
jaost's Avatar
found the problem! the switch on the dome light itself was damaged. Apparently poor workmanship where it was built. The current line for the door position was not properly set into the housing, so when the switch was used numerous times, it came loose. I might be able to reset the metal strip into the housing, but if not I will have to replace the housing unit.
bern10
Aug 21, 2021 9:52 PM
Chris1998
Sep 22, 2015 1:06 PM
paulg_ca
Oct 24, 2014 5:42 PM
RbJb
Oct 1, 2012 5:12 PM
deleontow
Cobalt
Jan 1, 2008 1:53 AM
