Chevrolet Malibu
Driver door trunk release, 2006 Malibu
Old Mar 9, 2011 | 8:34 AM
clandis2's Avatar
Default Driver door trunk release, 2006 Malibu
It doesn't work, but the trunk release on the key fob does work.
Can anyone help before I take it to the dealer?
Thanks!
Old Mar 9, 2011 | 9:23 AM
robbymorton's Avatar
Check both ends of the cable and make sure that it has not come out. At the handle and at trunk lock. If that's not it have somebody watch the lock while you pull the handle and see if its moving at the lock.
or is it electric? check fuse and relay? use a test light to check power to switch and the out side of the switch when the button is pushed. If they both have power check it at the trunk while somebody pushes the button.
Old Mar 9, 2011 | 11:16 AM
EinST's Avatar
It's electrical. The BCM senses the trunk release request when the switch grounds the circuit. Since the key fob works, the common path between the BCM and trunk latch (fuse, relay, and actuator) is good. Then, the switch must be bad (the lower edge of the door isn't the best place environmentally) or there's a wiring problem between the switch and the BCM or ground.
Old Mar 10, 2011 | 11:26 AM
clandis2's Avatar
Thanks.
EinST's explanation was what I was afraid of.
hands493
Jun 30, 2014 7:40 AM
a_rabid_dog
Jun 3, 2014 3:35 PM
blacey
Apr 19, 2014 11:05 AM
blueflirt03
Apr 22, 2010 8:10 AM
PAPADUKE512@YAHOO.COM
Apr 6, 2010 7:58 AM
