Chevrolet Malibu
Error code PO446
Old Oct 15, 2013 | 7:11 PM
jamair's Avatar
Default Error code PO446
Hi,
I have a 2001 Chevy Malibu with the error code PO446. It turns on the check engine light, but when I scan it, the code is inactive and have to refresh , then delete it from it's history status to turn off the check engine light. I've changed the gas cap and the EVAP value already. This happens only about once a month. Any help will be appreciated. Thanks
Jim
Old Oct 15, 2013 | 9:42 PM
jtho53's Avatar
Code P0446
EVAP Emission control System Vent Circuit Malf
Look up this P code to see how to repair it.
P0446 Evaporative Emission Control System Incorrect Purge Flow
Hope this helps you
John
Old Apr 5, 2014 | 2:28 AM
kobe3006's Avatar
Check out the purge valve Solenoid Under the rear of the car byt the Evap canister. its easy to take off hook a Small Sqaure 9 volt batter up to it and see if it clicks if it does it means its working. and it may be in the wiring
jre583
Apr 15, 2015 1:20 AM
bpayusa
Apr 22, 2011 6:34 PM
GregHamilton
Feb 6, 2009 5:12 PM
tshunt01
Feb 19, 2007 12:26 AM
Mother_Trucker
Sep 10, 2006 12:01 AM
