Front end creaking when you turn the wheel
I have a 2000 Malibu LS with 166,000 miles. When I turn the wheel in either direction I can hear a creaking noise on the front passenger side. Does anyone know exactly what could be the cause of that noise?
Sometimes the CV boot gets punctured, all the grease leaks out and they make a noise. Sometimes they just go bad. Although, I haven't heard of one going bad on a Malibu. Could also be a front wheel bearing. If these things don't seem to be the type of thing you can handle, then you need to take it somewhere. If you have some mechanical ability and some tools and you want to know more. Just ask.
Thx for your help. I'm very good with my tools and I have no problem working on cars. So please begin to tell me more.
I know it is not the wheel bearings because I changed those about 6 months ago. Seeing the A/C compressor came up with a shaft leak, I will be changing that out along with the belt and the tensioner pulley this weekend, I should have that passenger side wheel off and that will give me a better look of what might be going on with the CV boot.
could very well be the top strut mount that binds and let go as you turn the wheel, and the coil spring take the slack as it turns in the teflon mount. I had the same except the noise is more of a thump than a creack as I turn the steering wheel in either side.
Since the wheel bearings were replaced, check that the bolts haven't come loose or something strange like that. Also, I've heard that some aftermarket hub/bearing assemblies don't last very long.
I will double check the strut, but I don't think it is the strut just because when I go over bumps there is no noise. But when I sit still and slowly turn the wheel there is the noise.
This weekend I will raise both wheels off the ground and see if I can put my hand on the noise while someone else turns the wheel. That might be quicker than taking things apart and moving them around. don't get me wrong that is a good suggestion and I will use it if I can't get anywhere else with the car off the ground.
I'm think it would be the CV joint. I haven't seen traces of grease being slung all over the area where the CV joint is, but as you say it could of just wore out.
thanks for your help
After looking around at the CV joints and the strut I have found the problem. At the top of the strut the top of the coil spring is broken and when the strut turns with the wheel it makes the creaking noise. I had no idea the strut turned with the wheel..... I just never thought of it turning.
Thanks for the help.
dvfsu123
11
April 1st, 2016 12:29 PM
BaseballMom
January 14th, 2012 2:40 PM
