Chevrolet Malibu
Help!
Old Jun 13, 2014 | 11:20 PM
meganj's Avatar
Default Help!
Can someone please help me figure out what could be going wrong with my malibu?? it was running fine last night, this morning i woke up and went to start it, It cranked over once then stopped trying to crank over. Now it wont crank at all. Ive checked the battery, its good and as far as the fuses i think there all good.. what could this be??? on my dash in the message thing it tells me to service esc, service traction, and power steering??
Old Jun 14, 2014 | 7:02 AM
lagolfer's Avatar
Can you afford to have it towed to a mechanic ?
Old Jun 14, 2014 | 11:04 AM
How did you check the battery? A fuse could look good and still be bad. Also need to check the battery cables for corrosion at both ends.
Old Jun 14, 2014 | 6:23 PM
meganj's Avatar
No unfortunatly i cannot affort to take it to a mechanic, and we switched batteries and put a new one in and still nothing, idk what else it could be causing it to do this
Old Jun 14, 2014 | 8:31 PM
sledge.impy's Avatar
crankshaft position sensor?
starter?
Old Jun 14, 2014 | 10:21 PM
meganj's Avatar
Where is the crankshaft position sensor located? and i havent checked the starter yet. But i guess this is a common problem with some chevys, i was reading online and several ppl have had this same problem but different things causing it.
Old Jun 15, 2014 | 1:07 AM
meganj's Avatar
My boyfriend jumped the starter solenoid with jumper cables and the starter turns over but still won't start it (with the key forward). Also, when the key was turned on (before starting) the check engine light would come on for a second with the rest of the lights and now it's not coming on at all.
Old Jun 15, 2014 | 11:33 AM
Is it turning the motor?
Do you have fuel?
Old Jun 15, 2014 | 12:48 PM
meganj's Avatar
It only turns the motor when we jump the starter but not when we try turning it on with the key, and yes there is fuel.
