Chevrolet Malibu
How do I fix my abs, vdc, esc faults
Old Nov 21, 2023 | 3:00 AM
socialtaker's Avatar
Default How do I fix my abs, vdc, esc faults
Hello guys
I am a person who lives in South Korea.
I have a 2019 Malibu(Premier, 4Door Sedan, 1.35 Turbo), and this car has ABS and ESC errors, so I'd like to get advice.
Intermittent abs, vdc, esc errors while driving. If you drive like that, the error message disappears, but sometimes it does not appear for a while afterwards, and sometimes it reappears in less than an hour.
The scanner indicates a problem with the right front wheel.
Accordingly, we have taken the following measures through the official service center.
1. Right front wheel speed wheel sensor Replacement
2. Right Front Wheel Hub Bearing Replacement
3. Replace brake module
4. Wire exchange between brake module and right front wheel speed wheel sensor
But the problem has not been solved.
The cumulative mileage is 60,000 miles, and the battery has been replaced around 50,000 miles, and other consumables have been managed periodically.
Will the steering angle sensor need to be replaced?
Or is there anything else I can check?
Please give me your advice.
Old Nov 21, 2023 | 4:35 PM
Please post the results of the diagnostic scan
myinhousebigdog
Oct 27, 2024 10:39 PM
Retiredphoneman
Apr 29, 2009 12:05 PM
