Chevrolet Malibu
I want to make my crakshaft spin feely
Old Jan 11, 2014 | 4:44 PM
dbonjourjr476's Avatar
Exclamation I want to make my crakshaft spin feely
Hello, I want to make my crankshaft to spin freely with the engine still in. Im attempting to replace the rod bearings with the engine still in it and I cant make the crankshaft move a bit. Do i need to take off the tensioner?
If you could send some help this way. I've got a nice break in weather in KC.
Thanks you.
05 Chevy Malibu
2.2 liter
4 cyl
auto trans
4 door
Old Jan 11, 2014 | 6:02 PM
if you can't turn it with a breaker bar and socket on the crank bolt you have bigger problems than a bad con rod bearing.
Old Jan 11, 2014 | 7:28 PM
sledge.impy's Avatar
Hopefully- the car is also in neutral.
Old Jan 11, 2014 | 11:57 PM
makes no difference with an automatic trans.
Old Jan 12, 2014 | 7:43 PM
Camaro 69's Avatar
Site Ambassador
Removing the spark plugs will make it a lot easier to turn the engine over by hand, but even with them in, it should still be able to move "a bit". Make sure your starter gear isn't jammed into the flexplate, which would prevent you from turning it. Was the engine running up to this point? Or perhaps you spun or toasted a bearing, which would have "welded" the rod(s) to the crank.
mr.dudeman199
22
Mar 17, 2014 12:28 PM
boneskeys
Apr 22, 2011 11:36 PM
ace1015
Dec 13, 2009 1:48 AM
