Chevrolet Malibu
Malibu MAXX 2005 Remote starter stopped working
Old Feb 3, 2009 | 6:51 PM
mobilemodding's Avatar
Default Malibu MAXX 2005 Remote starter stopped working
A week ago It works, no no. Remote works ok, I can lock/open car/trunk but when I hit Remote Start it just blinks once and does nothing.
What may be an issue?
Old Feb 4, 2009 | 10:59 AM
slls's Avatar
Might need a scan with a Tech 2, but the most common problem is the hood switch. No, can not be bypass, it sends a signal to the PCM.
Old Feb 6, 2009 | 8:23 PM
mmaaxx's Avatar
Default similar problem
My wife's 04 maxx is doing the same thing with the alarm going off randomly. I just found the hood switch wires pinched between two plastic panels near the connector to the right of the latch. Could a faulty switch or a broken wire cause false alarm triggers. This happen once before and the dealer blamed it on a bad BCM and interior lock switch on passenger door.
Old Feb 6, 2009 | 9:12 PM
shawnvw's Avatar
Banned
If the bcm saw the hood open due to the pinched wires, then yes, That could be the cause of the alarm going off
Old Feb 7, 2009 | 1:29 PM
mmaaxx's Avatar
Thanks for the quick reply. Is there a quick test or bypass of the switch a shade tree mechanic like myself could do to before I order a latch/switch assembly from the dealer. The switch is not a servicable item, gotta buy the latch also at $100.00
Twainharteman
Jul 26, 2015 6:44 PM
Franks350
May 15, 2012 8:10 AM
2004MaxxLT
Mar 21, 2009 10:24 AM
Mr.K
Dec 18, 2008 6:00 AM
mobilemodding
Dec 7, 2008 11:39 PM
