Chevrolet Malibu
Malibu's auto stop feature is the pits. Can Chevy create a software disable function?
Old Jun 8, 2018 | 7:57 AM
  #11
oilcanhenry's Avatar
Originally Posted by tech2
doubt it. most stop start systems; the trans is completely off...they use a pressurized accumulator that primes the trans fluid pressure as soon as the brake pedal is released
Well, I admit defeat, Tech2. I never heard any noise from the transmission while in auto-stop mode, so that explains why. You are indeed correct about that.
I did check the auto-stop battery in the trunk. Its pretty much 'the size of a motorcycle battery and looks to be an AGM type as well. I'll have to research about disabling the battery/auto stop, as I am not going to pay $200-300 dollars for an M/C battery. I will always be a Chevy fan, but not including a donut spare tire, jack and wrench was pretty cheap on GM's part. I got a free tire air-pump anyhow!
I have a spare tire, jack & wrench in the trunk since not long after I bought it. That 2.5 liter mill will still average 25-27 city and 38-44 freeway, not the EPA sticker 25-36 MPG. She will do a solid 50 MPG at 55 MPH, Too bad that Chevrolet discontinued that engine in the new Malibu's, but I keep my cars for a very long time, and maintain them very well.
Old Jun 8, 2018 | 8:08 AM
  #12
the auxilary battery is used to power accessories when the car is off in auto stop mode, the main battery is for starting the car....battery state of heath would be on factor in the system disabling auto stop all by itself. If you disconnect the aux battery, I bet the system shuts off but you will get a DIC warning message. Look for fuses that run the system. Other inputs like driver seat belt, hood open etc may disable stop/start.
Old Jun 23, 2018 | 9:57 PM
  #13
Bob2LTZ's Avatar
Default Malibu premier no stop/ start feature
My 2017 Chevrolet Malibu premier thankfully does not have the dreaded auto/stop feature, but if it did I wouldn't have purchased the car. I don't see that much gas being save with this feature and yes, the EPA is out of control.
