Chevrolet Malibu
No crank
Old Nov 13, 2023 | 3:53 PM
VIKES's Avatar
Default No crank
I have a 2011 Chevy Malibu 2.4, when trying to start it makes a single click, and won't start. The lights, and radio will come turn on. I removed the starter and had it tested at O'Rielys. They informed me the starter was good. Any other ideas on what would be causing this problem?
Old Nov 13, 2023 | 5:12 PM
have you done any troubleshooting?
Did you try boosting it from another vehicle?
Old Nov 13, 2023 | 6:23 PM
VIKES's Avatar
The only troubleshooting I did was have the starter tested, and check the fuse for the starter. I will try jump starting it as you suggested to see if that works.
Old Nov 13, 2023 | 6:47 PM
If boosting gets it started, then have your battery and alternator load tested.
Old Nov 13, 2023 | 8:27 PM
VIKES's Avatar
Jumping the car did not work at all, it did the same thing a single click. The click definitely is coming from the starter. I tried tapping the starter as someone was trying to start it, and it didn't make any difference.
Old Nov 13, 2023 | 8:30 PM
was the donor vehicle running?
Old Nov 13, 2023 | 8:48 PM
VIKES's Avatar
Yes, I had the other vehicle running, I left them hooked up for a little bit, and still nothing. I also tried pressing the gas on donor car, while trying to start and it made no difference.
Old Nov 13, 2023 | 9:29 PM
ok so if power is good, and starter is good, that must leave the wiring. try putting the booster cables right on the starter. clamp the negative right on a starter mounting bolt and positive on the positive stud. You'll need a screwdriver or something to jump the starter solenoid .
Old Nov 14, 2023 | 6:11 PM
VIKES's Avatar
I removed the starter and tried jumping the starter. I noticed the starter motor spin but did pop out.
Old Nov 14, 2023 | 6:17 PM
*did* or *did not* ?
I said test it on the vehicle. Removing it won't test any of the electrical connections.
If the bendix doesn't pop out then the starter is faulty.
