Chevrolet Malibu
Oil life monitor
Old Mar 9, 2008 | 6:47 PM
LS6454's Avatar
Default Oil life monitor
Should I follow the Oil life monitor or the dealers service dept recommendations for oil changes, I have a 2007 Malibu LS with the 4 cylinder engine, My service advisor at the dealership recommends oil changes every 3000 miles, the OLM is still above 70% every time I get the oil changed. Any advice?
Old Mar 10, 2008 | 7:29 AM
steveho's Avatar
Default RE: Oil life monitor
Your oil life monitor is a compilation of several items that the on board computer is monitoring, speed, temperature, stops and starts etc.. It is meant to be helpful not a direct order. My advice is , if you drive enough to really heat up the engine on 20/30 mile trips change the oil every 6 to 9 months. If you make mostly short trips that barely get the engine heated up, change it at 3000 miles or three months.
Old Mar 10, 2008 | 11:06 AM
slls's Avatar
GM states use the oil life, there recommendation, I myself use 5000 miles.
The PCM compensates for short trips, low temp etc. Dealer needs the oil change money, will not make your car any better.
In the winter using oil life it will be about 5000 miles, in the summer 7500 miles or more.
wrrn73
Dec 17, 2009 6:16 AM
Vol4Ever
10
Feb 11, 2009 11:58 AM
MCF34
Dec 8, 2008 10:17 AM
Mercpuman
Jul 11, 2007 7:02 PM
readyman
Jun 30, 2007 5:10 PM
