Chevrolet Malibu
Overheating
Old Feb 2, 2010 | 12:09 PM
lostinlaton's Avatar
Default Overheating
mY 2003 CHEV MALIBU I REPLACED THERMOSTATE MECHANIC SAID IT WAS STICKING THEN I STARTED TO GET A ADD WATER LIGHT THIS LIGHT COMES ON AND OFF AND THE COOLANT LEVEL ALWAYS SEEMS LOW I CAN NOT FIND ANY LEAKS BUT NOW THE CAR IS RUNNING HOT AND THE TEMP GAUGE IS NOT SHOWING IT AND NOW THE HEATER IS NOT BLOWING HOT AIR
Old Feb 3, 2010 | 12:39 AM
reggie4828's Avatar
Default Re-overheating
I had a similar problem with my 03, I changed thermostat and coolant level was low for about two days. I searched the net and found out i had to bleed the system..I bled it Problem solved, topped off and good to go.You might have air in your cooling system.
Old Feb 3, 2010 | 8:43 AM
OnDaGround's Avatar
Banned
+1... there is a bleeder valve under, but near the throttle body. I believe its a white valve.
Old Feb 3, 2010 | 9:37 PM
reggie4828's Avatar
Thats right i forgot to mention that bleeder valve, It is located in front of the engine right next to the waterpump...3.1 engine.
jessejames
15
Nov 16, 2014 3:19 PM
87_caprice305
May 2, 2007 6:12 PM
Theflyer1
Dec 16, 2006 4:01 AM
jpp
Jun 5, 2006 11:30 PM
CliffGriffin
Jan 28, 2006 10:58 PM
