Chevrolet Malibu
Overheating Help
Old Mar 12, 2016 | 9:40 AM
Driven1990's Avatar
Default Overheating Help
I have a 2007 Chevy Malibu maxx lt that is overheating with in the first 5 to 10 mins of run time i have replaced the tstat and that did not work i have noticed that the coolant level in the resivor does not move when car is run or overheating i thinking i may be needing a water pump any other ideas on what may be wrong? How much of a pain in the *** is the water pump to replace? car has around 141k on it!
Old Mar 12, 2016 | 11:43 AM
cleveland63b's Avatar
you could try unhooking a heater hose and starting it up to check if its flowing the way it should. I'm assuming nothing changed after you do the thermostat?
Old Mar 12, 2016 | 12:09 PM
Driven1990's Avatar
yea nothing changed after tstat change still over heating as it was before! and coolant level does not change when running!
Old Mar 12, 2016 | 5:18 PM
Driven1990's Avatar
Ok update I just pulled the water pump and it seems to be fine the propeller spins with the pulley anything else that can cause this!!
Old Mar 12, 2016 | 10:59 PM
Goldenaxe's Avatar
Could be a blockage have you flushed it out yet?
Old Mar 13, 2016 | 11:56 AM
Driven1990's Avatar
yes i did last night after pulling pump! even with undoing upper and lower rad hoses the coolant level did not move in tank untill i removed the cap could i have had a big air bubble in the system?
Old Mar 13, 2016 | 12:17 PM
Goldenaxe's Avatar
It's possible, I've had it happen before but don't think it ever effected fluid level to the point your describing, when I did get air bubbles I would find a steep driveway and rev it a little in both directions for a few minutes. Did you see if fluid is even moving through radiator when you had it apart?
Old Mar 13, 2016 | 3:01 PM
Driven1990's Avatar
yea i took a hose a pushed water from upper rad hose and out the lower rad hose
Old Mar 14, 2016 | 7:30 PM
might want to do a combustion gas test on your cooling system also, I think you can get the kits fairly inexpensive
