Chevrolet Malibu
Owner
Old Mar 13, 2011 | 4:47 PM
MALIBU's Avatar
Default Owner
I have clunking noise in rear of 2005 malibu when your moving slowly over uneven road bumps.
Old Mar 13, 2011 | 6:44 PM
EinST's Avatar
I have to ask, is yours a Malibu or Classic? Trim level (LS, LT, MAXX LS/LT)? Have you had it in a shop yet?
Old Mar 14, 2011 | 3:04 PM
MALIBU's Avatar
Originally Posted by einst
i have to ask, is yours a malibu or classic? Trim level (ls, lt, maxx ls/lt)? Have you had it in a shop yet?
It is a malibu ls. I have not had it to a shop yet, but have removed both wheels and checked all supension parts / brakes and everything seems ok. Thanks!
Old Mar 14, 2011 | 5:34 PM
EinST's Avatar
So, your setup is similar to my 2010, springs/shocks rather than struts. It could be anything in that mess of links and bushings. If I had to take a shot in the dark, I'd check the upper shock mounting (should be torqued to 66 lb ft if single bolt, 18 lb ft if two nuts). It's something that's not really apparent with the shock at full extension under spring tension.
Old Mar 23, 2011 | 1:18 PM
Official GM Rep
Are you still having the clunking noise or has it been fixed?
-Jared Duane
Chevrolet Customer Service
Old Mar 24, 2011 | 9:47 PM
MALIBU's Avatar
Default malibu
Originally Posted by chevrolet customer service
are you still having the clunking noise or has it been fixed?
-jared duane
no we haven't resolved the problem. We still have clunking noise in the back.
Old Mar 24, 2011 | 10:25 PM
EinST's Avatar
Does it mean my suggestion of checking the upper shock mounting didn't pan out?
Old Mar 25, 2011 | 7:15 AM
MALIBU's Avatar
does it mean my suggestion of checking the upper shock mounting didn't pan out?
yes! I checked upper and lower shock mounts, everything ok. I also checked all rubber bushings and suspension . I jacked up wheel to relieve tension on shock everything tight. I bounced on rear of car and shocks seems tight. What next. Thanks jerry.
Old Mar 25, 2011 | 11:41 AM
EinST's Avatar
This "clunking noise," is it metal-on-metal clang or dull knocking-on-rubber sound? Check for a loose parking brake cable or exhaust mount? Remove the stabilizer link from the knuckle and and then see if the link isn't all worn out. Also, try removing the stabilizer shaft itself, link and all, from the vehicle and then test-drive it? A lot of times people object to stabilizer bushing noises which I take for granted, even on my relatively new Malibu.
Old Mar 26, 2011 | 12:10 PM
jeff_bod's Avatar
I have the same problem of sorts I dont get a CLUNKING sound but i get a squeek like a a metal on metal and at first i was determinded to find it but never could it only made noise while moving never when stopped So i've managed to live with it and all i do is turn up the music and then it fades away nicely.
P.S. the noise came from the back of the car in my hatch area. my Malibu Maxx LS
butch998
Uplander
Oct 31, 2006 12:17 AM
ice777
Uplander
May 24, 2005 4:55 PM
K5Carnage
May 21, 2005 6:38 PM
JoterFett
Apr 24, 2005 6:00 PM
motorush
Apr 6, 2005 4:31 PM
