Chevrolet Malibu
p0498 - evap canister solenoid valve 2 (n115): signal too low
Old Sep 11, 2022 | 5:12 PM
Caven's Avatar
Default p0498 - evap canister solenoid valve 2 (n115): signal too low
Hello, hope you’re well!
I recently failed emissions because of the following issue:
Can someone confirm what powers the evap canister solenoid? Is it the Fuel Pump Control Module (e.g., https://shop.advanceautoparts.com/find/2018-chevrolet-malibu-fuel-pump-control-module.c5506)?
I replaced the following in hopes of solving the problem:
- Vapor Canister, including the Vapor Canister Vent Solenoid
- Canister Purge Valve
At this point, from my research it’s 1) wiring (not sure I can find root cause given my knowledge/ experience) or 2) the PCM (powertrain control module.
That said, when I spoke w my dealer Parts rep, he said that it’s powered by the the Fuel Pump Power Control Module (https://shop.advanceautoparts.com/find/2018-chevrolet-malibu-fuel-pump-control-module.c5506).
Can someone please help me confirm what powers the component in question? Before I take it in to the dealership, I’d like to rule out if it’s the Fuel Pump Control Module, which I understand is in the trunk and easy to replace.
Thank you. 🙏
Old Sep 11, 2022 | 11:21 PM
oilcanhenry's Avatar
Can someone confirm what powers the evap canister solenoid? Is it the Fuel Pump Control Module (e.g., https://shop.advanceautoparts.com/fi...module.c5506)?
That said, when I spoke w my dealer Parts rep, he said that it’s powered by the the Fuel Pump Power Control Module (https://shop.advanceautoparts.com/fi...l-module.c5506).
Thank you. 🙏
You'll need to clear the code out to make sure it's repaired.
Old Sep 12, 2022 | 1:03 AM
Caven's Avatar
Yes, I have cleared it, but it comes back…first “Pending” and then confirmed.
Thanks!
Old May 17, 2023 | 4:39 PM
Wilson3269's Avatar
Did you ever get this fixed? I have a 2018 with same code. I have replaced fuel pump control module and canister but code still active.
chevy325
Apr 7, 2025 11:46 AM
rogarm
Jan 20, 2015 4:25 PM
arminkropp
Uplander
11
Apr 1, 2010 10:57 PM
JRT600
19
Jun 4, 2009 11:44 AM
