problem in speedometer and speed indicator
hi guys, i have a Chevy malibu ls 2002 and in the last few days, i started seeing some problems in speedometer, sometimes the speed indicator start playing from 0 to 40 then goes down to zero then back to 30 or any other number. sometimes when i just started driving the speed indicator stuck in a 0, then when i push the gas very strong the speed indicator goes up to 30 or whatever the speed is. one day i experience a problem in a transmission so when i switch from park to drive or reverse a big noise happened in the engine then the check engine appeared, and after one day the check engine went off. i do not know what is the problem. if there is any solution to that please tell me.thank you.
There is a speed sensor in the transmission which sends a signal to the speedometer. This is probably bad or the wiring to it is bad. Don't know where it is on your car, but should not be too hard to change? You need to read the code when the light is on. Go Autozone when it appears and they will read the code for free.
Former Sponsor
Remove dash face plate and gauge cluster and Disassemble cluster. Inside the cluster stepper motor is located and holded by 4 points.
j_cook
February 26th, 2014 12:35 PM
ericnottelin
August 6th, 2012 9:09 PM
jefferino
May 11th, 2012 11:27 AM
5:00 PM
January 7th, 2012 11:38 AM
2012, average, car, check, chevy, cluster, indicator, malibu, problems, spedometer, speed, speedometer, speedometernot, stuck, working
