Chevrolet Malibu
shimmy when brake applied
Old Nov 15, 2017 | 12:35 PM
lbgolfman's Avatar
Newly Registered
Default shimmy when brake applied
09 chevy Malibu LS. sometimes breaks smooth, sometimes vibrates a little, sometimes very bad, sometimes growls. seems like from the right front
Old Nov 15, 2017 | 12:59 PM
speedOhead's Avatar
could be bad rotors, bad hub bearing. is the shimmy in steering wheel as well?
Old Nov 15, 2017 | 6:10 PM
bandit_601948's Avatar
sounds like the brake rotors are out of round ! if your rotors are still thick than try to have them turned, if not than you might have to buy new rotors ! also you might consider changing the brake pads !
Old Dec 12, 2017 | 7:00 PM
jampg's Avatar
we just replaced all the rotors and pads and one rear caliper on an 09. The mechanic said keep an eye on uneven pad ware due to calipers seizing up. That will ruin a rotor quick. 140,000 miles
