Chevrolet Malibu
TRANSMISSION STUCK IN PARK
Old Nov 16, 2007 | 3:07 PM
txsugarbear's Avatar
Default TRANSMISSION STUCK IN PARK
[]My malibu is in the garage and I can't get itout ofpark. I pumped the brakes..I held in the button on the stick...nothing.....Help!!!!! Someone at the chevy dealer (grrrr) told me it might be the brake switch?...ok...blondefreeze here...WHY would it have anything to do withthe brakes. Thanks in advance!!!
****Combined consecutive posts*****
MAKE THAT P A R K SORRY
***Please use the edit function to add corrections or afterthoughts to your post.***- EuroGoldLS
Old Nov 16, 2007 | 4:04 PM
EvansBlue's Avatar
Default RE: TRANSMISSION STUCK IN PARK
The reason he told you it has something to do with the brakes is because you have to press the brake to shift from park. When you press the brake about a quarter of the way down, the pedal trips a switch that allows to depress the button and shift from park.
What model Malibu is this and how exactly does the shifter behave? Does it freeze and not move, or can you move the stick into reverse. Knowing this will indicated whether you have a linkage problem or a transmission problem.
Old Nov 17, 2007 | 7:55 AM
I have a 1997 Malibu
BigblackHo3
Apr 5, 2013 8:54 AM
bdm408
Sep 7, 2008 6:24 PM
fredski53
Jul 21, 2008 11:45 AM
bdawg0958
Sonic (Aveo)
Nov 18, 2007 2:07 PM
bdawg0958
Nov 5, 2007 3:55 PM
